Compass 2005 640 Internal Door
Apr 8, 2007
18
The internal door between the living area and the toilet/shower area front roller has come off the track making the door virtually unusable.
I have tried to lift it back into positon but with no success, also tried to take roller off but looks like you will have to strip half the caravn down to do anything with it.
Has anybody had a similar experience, if so how did you fix it?
Thanks, John
Mar 19, 2007
348
Exactly the same problem has developed on ours, thought I'd fixed it but retruned next time we towed. It goes in for service on Tuesday when I will discuss this with them, to be done under warranty. If I learn anything from them I will let you know how they intend to fix it.
Alan
Mar 19, 2007
348
Took van in yesterday, technician couldn't say what they would do until they had inspected the door, will report back after I have collected the van on Friday
Sep 13, 2006
1,411
If you are talking about the concertina type blind we have one on our Corona 636 which did this, to get it back in we hold the stiff section at an angle to reinsert the top.
I am thinking of putting a small screw into the wall at the end of the track to stop it reocurring.
Mar 19, 2007
348
Thanks Garry but in the 2005 Rallyes it is a solid door suspended on 2 rollers and supposedly held in place by a guide track. Ours jumps off the track when travelling.
Jul 11, 2005
657
We had the same problem with our Elddis solid door.
Every time you used it the bottom spring loaded plunger jumped out and jamed.
I fixed it myself by repositioning the bottom guide on the floor. It was about an inch out.
It was easy to do and is now perfect, no more jumping out at all.
Hope this helps
Edd
Mar 11, 2007
585
Hi everyone.
My previous van (a 2004 Compass) with a solid sliding door had the same fault. During its 3 year service the engineer said that it was a common fault with the upper rollers breaking. The fault would have been rectified under warranty but I had already done a p/x with the Compass so there was no time for me to have it reified but I trust that it was fixed before it was sold on.
Mar 11, 2007
585
Hi Brum,
Nice to know that I am not the only Brummie on here.
Graham W.
Graham of SW Brum
You are not alone here-------Look at your recent post on the UK Sites forum.
Brum
PS what area of SW Brum are you? I an B32
Aug 13, 2007
703
Hi Brum,
B31, neighbour. We rally with the British Leyland ccc Longbridge section. There are 15 companys that used to make up BL most of them now put to sleep but their ccc sections still thrive, so that we can go out with Land rover, Jaguar, Wolsely, MG, Standard Triumph etc.
Graham W.
Hello John and all who own one of these dispicable vans. Yes we did certainly have the same problem with our 05 Omega. Same set up as you have said and in 3 Yrs of owner ship the dealer and manufacterur, if you can call them that couldnt put it right. We did hear a bit of info from another dealer that on some 05 vans from this maker, had suspect floors, as in they could not suport the van body. Caused the floor to flex and broke the seals around the floor on all sides. Armed with this and the fact that the doors on our van, would not stay on the tracks, we chopped it in for a better built van. Hope this has'nt upset anybody, but I feel you ought to know the possibilities of your van being very similar. Bazz.
