Does anyone use those moisture trap thingies , the ones with the crystals , and do they work ? . Thinking about leaving one in caravan while stored for the winter . Thanks
Rita said:I have in 30 years of caravanning only ever drained down, Pulled cushions away from wall,Leave all doors open and never had a problem
Prof John L said:It is of course a personal choice whether to use dehumidifiers or not. but it may be helpfull to understand how condensation is caused.
All air has some moisture content known as humidity but how much depends largely on temperature and the available source of evapouratable water. Warm air can carry more moisture than cooler air. This demonstrated very well by the ferocity of the rainy season in hot tropical climates.
When a caravan is used (in the UK) it is usually kept warmer inside than outside, so the air inside the caravan can be more humid than the external air. The largest sources of water to raise the humidity are from the occupants breathing and any open flames such as the cooker and oven burners, and boiling water.
Any warm humid air that comes into contact with a cooler surface, will cause the air to cool, and if it is taken below its dew point it will deposit some of its moisture as condensation. (That is the reason we get dew on the grass etc and how it rains).
So during use, a caravan will attain a higher overall moisture content in the air and other materials such as the mattresses, curtains and untreated wood etc. As a consequence, when a caravan is put into storage and it cools down some of that raised moisture may appear as dampness.
It can make sense to use a dehumidifier for a couple of days after usage, but the benefits beyond that will diminish towards zero unless the caravan has a leak when it rains.
Over a longer period a dehumidifier will continue to collect water but its benefit to the structure and content of the caravan will diminish as it dries out, however as caravans have fixed ventilation (which is necessary as it is a habitation module) there will always air exchange with the outside, so increasingly all the dehumidifiers are effectively doing is collecting water from the outside air as it passes through the caravan and have virtually no impact on the condition of the caravan.
The best way of controlling and minimising condensation is to keep good ventilation with the ambient air.
