Three methods of DIY all of which will work, but, if I could make a couple of comments.
First don't coil the excess cable tightly, the current drawn by fridge and battery charging will overheat the cable. Also the coiling and extra length will increase the voltage drop to these two functions. long loops are much better or cut the cable to length.
As for 10A connection blocks, I don't pay attention to stated amperage rating but pick the hole size closest to cable size, 3A and 5A are best, they don't overheat. Or using a bigger size, bare enough wire to pass near enough through the connector, this way you use the connector screws to clamp the wires to each other.
Fitting two cable into a hole designed for one, make sure you seal the inevitable gaps against water ingress.
Don't think for one moment it will only take '30 minutes'...you fall asleep Jen?! lol
