Couple of Questions from a Newbie
Aug 1, 2018
Hi
I am really new to this caravanning thing.
Bought a cheap old van to try it out.. a Baileys Discovery 444
Everything seems fine with it and all seems to work.
Can you tell me.
1. Does everything switch over automatically when you hook up to 240v or do I have to throw some with in the van?
2. Does the leisure battery charge while on 240v hookup?
3 does the leisure battery charge whilst towing?
TIA
Regards
Rob
1,437
Rob, Not sure about the first question, as some older caravans will have a master switch and some will not. It would normally be labelled, if there is one, and near the door. Can you advise the year of the van as that would help if no one on here has that model.
The caravan should have a charger that will charge the battery when on a hook up.
In theory the car will charge the battery when you are towing but this is minimal due to the thin wiring and the length of the cables. It should however keep a chilled fridge cool but will not cool it down if it has not been cooled earlier.
May 24, 2014
3,687
760
To answer your questions, most vans will have a power switch to actually turn the power on. Being sensible, you should hookup first and then turn on.
The leisure battery does charge whilst on hookup with modern type vans, whether you have a single stage or three stage charger depends on the caravan itself.
If your towcar has been correctly wired, the leisure battery will charge whilst towing.
With a leisure battery, its important to keep it in tip top condition, its very difficult to resurrect a deeply discharged leisure battery. Try to find out how old your leisure battery is, they dont last forever.
Aug 1, 2018
Thanks for the rapid replies guys.
The caravan is 2002.
I bought a new leisure battery as the one that came with it was knackered.
All looks good!
Rob
2,403
Raywood said:
Rob,... but will not cool it down if it has not been cooled earlier.
Not true.
A fridge running on 12v from the car WILL cool down, But it may not be as effective. All absotrbtion fridge uses heat to drive the heat transfer fluid around the cooling system. That heat is sourced from any one of three sources, Mains electric, 12v DC from the car or burning gas. Each of the three possible sources are roughly equal in heat input ratings, so any of them will drive the system and allow it to cool the fridge.
The fridge needs several hours to cool from ambient to it's working temperature, given enough time on any of the fuel sources and it will cool down. The difficulty with 12vdc is that often the engine of the car is not running long enough to fully cool the fridge, and the motion of the caravan when being towed can upset the flow of the refrigerant around the circuit reducing its efficacy.
It is best to pre cool the fridge on mains or gas prior to any journeys, and use 12v to maintain its operation whilst towing. Another good trick is to keep all fridge items in a comedy fridge before a trip, and only transfers them at the last minute, and if possible use a pre frozen freezer pack at the top of the fridge to help keep things cool. A pack of frozen peas might do as long as you intend to use them in the first few days of the holiday.
Mar 27, 2011
1,332
505
19,435
No one seems to have mentioned that the fridge will only cool when driving and same with the battery charging while driving if the OP has both plugs fitted with his towbar electrics.
BP
4,815
BP
Doesn't above post from Prof say that it will only cool when the engine
is running? I think most would assume that to be when driving the outfit.
May 27, 2014
219
10,585
Basic Towing Electrics
What is a 12N connector on a car?
The Normal power required by the caravan/trailer for indicators, brake, fog and sidelights are provided via the 12N connector. This is a socket on the vehicle and a plug on the caravan/trailer.
What does it look like?
The socket cover is usually coloured black and houses 7 pins which are numbered 1 to 7. The plug is also black and has a slot that locates opposite the cover hinge of the socket. The central contact (number 7) is female in the plug.
How are the 7 pins connected?
The 12N connector needs to be connected using the correct wiring according to DIN/ISO 1724, pin connections as in the following table and picture:
12n
Pin Cable Colour Function
1 Yellow Left turn signal
2 Blue Fog lights
3 White Earth
4 Green Right turn signal
5 Brown Right hand side light
6 Red Brake lights
7 Black Left hand side light
What cable should I use?
12N seven core cable has a black outer sheath. Each of the seven wires within should be around 0.65mm² and sometimes a larger earth wire at 1.0mm². They are usually colour coded as in the previous illustrations.
Are the cables always the same colour?
No, some dedicated and original equipment kits use the wire colours specific to the vehicle manufacturer.
What is a 12S connector on a car?
The Supplementary power required by the caravan reversing lights, interior lights, battery charger and fridge are provided via the 12S connector. This is a socket on the vehicle and a plug on the caravan/trailer.
The socket cover is usually coloured grey or white and houses 7 pins which are numbered 1 to 7. The plug is also usually grey or white and has a slot that locates opposite the cover hinge of the socket. The central contact (number 7) is male in the plug.
The 12S connector needs to be connected using the correct wiring according to ISO 3732, pin connections as in the following table and picture. Please note; Make sure that when you wire the 12S socket you independently earth wires 3, 5 & 7 to the car. If the split charge relay in the car allows it, connecting the blue wire from pin 2 to the second switched output terminal will ensure compatibility with pre and post 1998 caravans.
12s
1 Yellow Reverse lights
2 Blue Charge ->'98/Additional fridge
3 White Earth for pin 4
4 Green Interior lights/Charge post '98
5 Brown Unused/Additional earth
6 Red Fridge
7 Black Earth for pin 6
12S seven core cable has a grey outer sheath. Each of the seven wires within should be around 1.5mm² and a larger white earth wire at 2.5mm². They are usually colour coded as in the previous illustrations.
What is a split charge relay?
The relay splits the power supply from the vehicle to the 12S connector.
Why is the relay needed?
To avoid a flat battery on your vehicle the relay isolates the caravan from the vehicle when the engine is off apart from a permanent supply to the caravan interior lights through pin 4.
What happens to the split charge relay when I start my engine?
When the engine is running the relay will provide power to pin 4 and also pin 6 for the fridge and if wired for pre 1998 caravans pin 2 for the charge circuit, this can also be used as an extra power feed for larger fridges in post 1998 caravans.
What happens to the power from pin 4?
Modern caravans have a built in relay that switches this power when the engine is running from the caravan interior lights to the charge system for the caravan's own battery.
How can I tell if my caravan has this facility?
All caravans built from September 1998 should have this facility. Most caravans built before then use pin 2 as a battery charge supply.
What is a 13 pin connector?
Some vehicles or caravans may come equipped with one single connector that incorporates both 12N and 12S functions, this is known as a 13pin or continental type connector.
The socket is usually coloured black and houses 13 pins which are numbered 1 to 13. It also incorporates a twist lock mechanism that secures the plug to the socket.
How are the 13 pins connected?
The 13 pin connector needs to be connected using the correct wiring sequence according to UK an European specifications as in the following table and picture. Pins 1 to 8 usually use 1.5mm² wire and pins 9 to 13 usually use 2.5mm² wires.
Pin UK Cable Colour
ISO 1724/3732
European Cable Colour
DIN/ISO11446
using 13 core
cable 1.5mm² Function
1 Yellow Black 7 core cable .65mm² to 1.5mm² ea. Yellow Left turn signal
2 Blue Blue Fog lights
3 White White 2.5mm² Earth
4 Green Green Right turn signal
5 Brown Brown Right hand side light
6 Red Red Brake Lights
7 Black Black Left hand side light
8 Yellow Grey 7 core cable 1.5mm² to 2.5mm² ea. Pink Reverse lights
9 Green Orange 2.5mm² Permanent live 30+
10 Red Grey 2.5mm² Switched live 15+
11 Black White/Black 2.5mm² Earth for pin 10
12 Brown Unused Unused/additional earth
13 White White/Red 2.5mm² Earth for pin 9
13 pinCan you use 12N or 12S sockets/plug with 13 pin?
12N and 12S is not compatible with 13 pin, however adaptors are commercially available to interchange between both systems.
Is there a system that uses both 12N and 12S functions in one socket?
The West 13 pin socket looks like a standard 12N 7 pin socket but includes extra pins between the standard 7 pin configuration so either a standard 7 pin 12N plug can be used for a trailers and light boards or the specific West 13 pin plug for caravanning.
How can I tell if the towing electrics are operating correctly whilst driving?
The electrical kit for your vehicle will have a tell tale supplied which will inform the driver of an indicator failure.
What is a tell tale?
This is a device that tells the driver that the indicators on the trailer are operating correctly. It can be an audible beeper or a dash mounted warning light that operates in time with the indicators and stops if an indicator fails. Some will only operate if an indicator fails on the trailer others notify the driver of indicator failure by making the vehicles own indicators flash at a faster rate.
How often should I check my caravan/trailer lights?
A full light function check should be performed every time you connect.
What happens if a brake bulb fails on the trailer?
Ordinary electric kits will not register this however with some dedicated kits a message will appear on the dash (model dependent) to warn you of the failure.
What is a fog lamp ‘cut out’?
This disables the vehicle's fog lamp when towing to reduce reflective glare from the caravan/trailer.
Do all cars have a fog cut function?
Some wiring kits have this function as standard otherwise you may have to request this at installation.
Can I fit the electric kit to my own car?
Modern electric kits come complete with instructions, if you have any doubts you should always employ an approved stockist to install your electrics.
What happens if a bulb fails on the car?
In most cases the lights on the caravan/trailer will still operate, the bulb should be replaced as soon as convenient. If the vehicle has bulb failure monitoring, multiplex or CAN bus wiring, you may be notified of a bulb failure, this is model dependant.
2,403
BP
All modern cars use alternators to generate and meet the cars electrical needs. Even at tick over, many will produce some excess power and can deliver it to the fridge in a connected caravan. Consequently the car does not always have to be "driven" for the fridge to recive power. However in some cars it may be necessary for the engine to be running at higher revs for the alternator to produce enough current to power the fridge, and that might only be practical when being driven.
May 24, 2014
3,687
760
Conversely, if the cars electrical systems are dragging too much power, the fridge supply will be stopped. Scenario, a wet foggy day, heated screen, wipers, air con, heated seats, lights and radio, my fridge will cut out.
4,815
In that scenario I doubt the fridge requires much cooling anyway so it’s insulation will suffice until the weather improves or the heated seats are turned off :)
