Hi All,
We are new to caravanning, and have just returned from our second trip. Few lessons learned, (such consider Propane in March as its pretty chilly at 04:00 otherwise and Mrs. K isnt happy then!) but on the whole, things are going well, towing, reversing, awning etc etc.
I purchased a new jockey wheel assembly over the winter, our existing phneumatic one had a badly degraded tyre, and the knob on the top was missing, so replaced the whole unit. The new one came with a clamp which id like to fit, however, when I removed the a-frame cowling, although I could easily get to both nuts, I could only get to the head of one of the bolts holding the clamp assembly onto the frame. I didnt opt to undo anything as the last thing I wanted was to have a loose clamp! Does anyone know how i get on the left hand bolt (when viewing the clamp from the front). Caravan is a Swift Challenger 490/5SE 1990 model.
Also, I keep seeing vans that are pitched whith the jockey wheel raised. Am i supposed to be doing this? Generally I have placed a short piece of board beneath the wheel, levelled the van, lowered the steadies, then left it.
Although the tyres look 'ok', im about to replace them for new, mainly for piece of mind. Ive seen some GT Radial Maxmilers (175/80/13 C 97N) The load rating is 730kg (if im correct) which is well over the MTPLM of the van - 1175kg i think, but i know definately below 1200kg! Are there any opinions of this tyre, or does anyone know of anything bad with them!
A long shot this one - I have two 240v lamps at the front of the van, I cant recall ever using them, but in any case, both dont work. Does anyone know if there is a 'standard' place for a fuse for these lamps? I havent had a good look, but if there is a good place to start, it would be appreciated.
Oh, and one last thing! Is it possible to change my waste water outlets to the more common 32mm pipework? I have 3 lengths of pipe that is approximately 20mm across, and its such a pain getting all three into the neck of the waste roller. I was thinking, if I could change to the 32mm pipework, I could then use a load of the fittings I have spare from doing household DIY to make up one of those gucci drainaway contraptions!
Thanks in advance.
Regards
Rob
Thanks in advance.
Regards
Rob
