Covid for the first time
Feb 13, 2022
553
407
1,135
Finally my luck has run out. I've had a very runny nose last few days, I assumed it was on going sinusitis from previously posted "infernal cold". Had the day off work today due to shoulder pain and generally feeling a bit grotty. Ate a pasty for lunch today and thought it tasted a bit odd. Decided to test, expecting nothing . Lo and behold, took a passing glanceswhilst after doing a couple of things while it processed, a line next to "T". Not the strongest, but clearly there. Oh well. At least it'll be out of way before Easter and won't interfere with important things like caravanning!
1,823
Hi Chris I hope you get well soon
Feb 19, 2023
10
This happened to my wife and me as well ! We had both been feeling really tired with symptoms of a cold, and she did a test, something we haven't thought of for ages. Turns out it was positive - and so was mine.
We had managed to avoid it by being so careful since the beginning, and thought is was all now in the past. It turns out that there are still plenty of cases around, it just doesn't make the news any more.
It actually took 10 days before we got a clear reading. It gave us a good reason to take plenty of rest, as we wanted to allow the best chance of a good recovery. Going on our first trip with our new caravan in two weeks, so didn't want to miss that !
I will certainly revert to wearing a mask in the supermarket now ...
4,842
You’re right about cases ONS report around 1 million per week are infected. It’s causing chaos with our attempt to move my brother in law from a care home in Coventry to one in Wiltshire. The one in Wiltshire had a case of covid so effectively closed its doors and tested all. It required a minimum period of 14 days before further LFT and PCR tests have to be negative. The PCR results were due this last Monday, today they have some but the balance should be reported by Friday. In the meantime the NHS in Coventry who are funding his care there are putting pressure to move him out. Understandably because his room in the Coventry care home is required by other hospital patients requiring discharge and assessment.
2,403
22,935
Covid infection does seem to be increasing however it does not seem to be as serious as the original infection. No mention of latest death rate.
1,006
Contagion seems weird. Friend of mine got it for the second time. Positive for about 7 days. His spouse didn’t get it. Our daughter had it, went into work thinking it was a bad cold. Sat in a team meeting with a number of colleagues, tested when she got home and found she was positive. Thought she would have infected them all. None of them caught it, or at least none got any symptoms.
Still need to be aware though as clearly our friend and daughter each got it from somewhere.
1,823
I am pleased you both are on the mend and you can look forward to your first break i have been wearing my mask for some time now at supermarkets and shops .
2,684
This long lasting cold , cough, blocked up etc strikes me as a possible Covid variant although the C19 test shows negative. I don’t see many mask wearers now nor do I see anyone using the trolley cleaning stations at supermarkets?
Reactions: Pamplona
1,823
Hi Dusty we went to Tesco supermarket yesterday i saw alot customers with a mask on but not many using the trolley cleaning stations .
2,403
22,935
We did the same and both negative for the test. OH still uses the trolley cleaning stations however neither of us wear masks. Trolly cleaning stations should have bene made compulsory many years ago with similar applying to baskets.
Aug 24, 2020
221
124
1,635
I've escaped so far, even though Mrs Gozza and Gozza Junior (who was staying with us at the time) had it over Christmas. I think it's partly that working in a hospital means I've had the jabs and boosters ahead of others in my age group.
Jan 20, 2023
269
195
235
I got struck down with it this time last year. I was grotty with cold-like symptoms BUT the weird bit was the very vivid dreaming at night. I have never experienced anything quite like it. Apparently sleep-disruption is one of the possible side effects.
Jun 16, 2010
335
142
18,735
I felt rotten the week before i tested positive, and worse the week after (when i was testing negative)
Our first time, and right over christmas too.
2,162
I am in the, "Vulnerable" group of people, due to my immune system being low, so have now had 5 lots of Anti Covid jabs, 3 different lots.
I go out, socialise, I don't wear a mask. With the latest variety of Covid I think it is important that people get exposed to it for their own body's immune system to fight the virus, and of course this will show up as cold and flu like symptoms.
Let us not forget that The Flu and Pneumonia, are also deadly.
I think if people have symptoms and have to go out then wear a mask to help others.
Feb 19, 2023
10
Thanks, Beachball - we certainly are looking forward to our trip - hoping for a bit warmer weather !
Feb 13, 2022
553
407
1,135
Just tested again today. Still positive. Stonger line than Tuesday! Annoying because I don't feel that ill. Never mind. All is not lost. Sending dad to to offy to pick up some beers and drop them at my door. ;)🍺
2,162
I told my wife that I had border line tests, kept on the Hot Toddy's for a full week until she sussed me.
Hope you recover well.
2,419
According to John Hoskins University who have been at forefront of researching the epidemiology of both COvid 19 and the ongoing Flu variants. There are many similarities between the transmissibility and infection rates of both Flu and Covid, but the biggest and most serious difference are the longer term consequences of becoming ill with the viruses and in particular the mortality rates which contrary to the common comments we see, Covid is still roughly ten times more fatal than flu.
"Coronavirus vs. Flu Deaths
Flu: The World Health Organization estimates that 290,000 to 650,000 people die of flu-related causes every year worldwide.​
The COVID-19 situation continues to change, sometimes rapidly. Doctors and scientists are working to estimate the mortality rate of COVID-19. At present, it is thought to be substantially higher (possibly 10 times or more) than that of most strains of the flu.​
Feb 13, 2022
553
407
1,135
Currently "thought to be ten times more fatal the flu". "Thought" is not necessarily fact All through this pandemic we have been told to listen to "the science", as if it is one single immutable entity. There are all too many voices of doom and gloom in the media and swathes of the so called scientific community who would have us in masks and lockdowns forever more. Restrictions which were based on advice from "experts" such as behavioural psychiatrists and ridiculous projections of people like Neil Ferguson all dressed up as "The Science". It has been revealed by the Hancock WhatsApp messages that there was an intention to "scare the pants" off us. The majority of the media focused on the negativity. I prefer to listen to more rational people such as Prof Carl Heneghan, Prof Sunetra Gupta and Dr Renee Hoenderkamp. To be honest, these days I just prefer not to worry and get on with life.
4,842
I just say “ vive la difference” There’s not enough expertise on a caravan forum to provide a knowledgeable and balanced debate. Just let everyone do what they think is best for them. We have moved on from 2020-22 why resurrect old views.
Feb 13, 2022
553
407
1,135
Well that's true. I've made my point anyhow, so I won't keep on.
1,823
Hi Chris keep taking the hot drinks and you soon be on mend
