Creaking floor
Apr 19, 2005
32
The floor of our 2004 Lunar Lexon EB has developed a creak as you walk across the area between the door and the kitchen. I mentioned it to the service agents when the 'van was serviced in early March and they suggested that it was due to some of the 'furniture' not being properly fixed back after the last service - done by an agent I would never use again!! They say it is not due to delamination.
The floor still creaks and it appears to come from the floor, could this be due to the steadies not being tightened correctly?
Any thoughts?
Regrads,
Tillman
Jul 11, 2006
305
Hi Tillman, If you look back to about page 4 on this topic you will find a thread which covers similar problems have a read.
Oct 24, 2007
96
Hi Tillman
I had the same problem It was suggested I tighten the bolt under the van on the main chassie member @ it worked so is worth a try,
Best of luck Mick K.
