I think I am able to post now after a few failures.
I am after a bit of advice re my Bailey Ranger caravan.
On our last outing we had just set off home when we heard a slight creaking from what we assumed was the hitch. Whilst travelling straight or through normal bends in the road no problem, but when making actual slow speed turn both left and right at road junctions we had the creaking sound.
We were able to stop within a short distance of hearing it and were also lucky to be able to pull onto a virtually deserted industrial area.
I unhitched the van and checked the stabiliser pads they were lined up ok no breaks cracks or grit and the tow ball was clean and dry.
I even pulled and tugged at the tow bar on the car having convinced myself that it was about to fall off but all was well.
I re-hitched the van but did not engage the stabiliser I then drove along the road making tight slow speed turns and again we had the creaking.
I re-engaged the stabiliser and then carried on home stopping about four times at various laybys to make sure everything looked ok.
The van towed fine other than the slight creaking a junctions.
I will have to take the van back to the dealer (100 mile round trip) because we are covered by warranty but would like to have some kind of an idea of what the problem could be.
I would appreciate any thoughts anyone may have.
I should have mentioned the van was serviced in January and has only covered about 400 miles since.
Best regards to all
Brian
Best regards to all
Brian
