Hi all
My 5m LED Strip has arrived, I've tested it and it works.
Before I cut it I just want to ask. Can the cut off piece be used also. If so, then really I take it that this can be cut into 10pieces for example and each wired individually. Can I assume that the cut end will need wire soldered onto the strip to connect it to the circuit?
I do hope that makes sense!
Twindaddy
Twindaddy
