This may seem a daft question, but I can't work out were the safe place is to place a scissor or bottle jack.
We have a brand new Abbey Vogue and are off to the Lake District in a week's time. I've been trying to get to grips with everything before we go. I've been going through the caravan's manual and associated literature and can not work out where to place the jack (should I need to change a wheel). It says in the Alko literature that there are two holes in the chassis behind the wheel for their own side lifting jack. No problem, I can see them.
However it also says that as an alternative you can use a scissor jack or a bottle jack on the re-enforced axle plate. Well I'm blowed if I can find anything that remotely resembles a re-enforced plate!!. There is a sort of triangular plate near the axle which seems to join two pieces of the chassis together. My worry is that it says in big letters "do not jack up on the chassis". All well and good if you can differentiate between the normal chassis and this so called re-enforced plate. Any help most welcome.
cheers
cheers
