Is there a tool you can buy , so you can re sharp your awning rail ,mmy awning keep comeing out running rail at the weekend
can any one help thank stuart
thanks every muchHi Stuart ,
Yes there is a tool you can purchase from any good caravan accessory shop , but this tool is usually for reforming a awning rail which is closed up or tight on the awning beading . I am sure that if you ask at the afore said accessory shop they will advise . All the best at rectifying your problem which I am positive you will achieve .
STEVE.
thanks good ideaYou could try a block of wood, a hammer and gentle persuasion to close it down a bit. If you go too far then the opening tool mentioned above can then be used to set the right gap.
