Trying to sort out some damage in my recently acquired 1994 Bailey PageantCD Auvergne and would welcome any advice anyone may be able to offer:
1) Blind/Fly screen cassette. Bailey owner's handbook states they are "Remis" make.
The one covering the right side window on the front. The cap on one of the top ends is broken and the blind has broken free from the bottom edge bar. I removed the other top end cap and the 3 screws at each end of the top casing and the single visible screw from each of the bottom ends of the sides but there must be another screw at each of the bottom ends which is impossible to see and impossible to access with a screwdrive as it is so close to the window sill. It appears that during manufacture the front window cassettes must have been affixed to the front wall before the window sill and centre drawer unit were installed. Does anone know if it is possible to access these screws without removing the drawer unit and window sill? If not, how difficult is it to remove the window sill?
2) Two of the window stays have damaged locking collars. The stays appear to be easily removeable. Does anyone know whether they are still in production and fitted to current models?
3) All the curtains need to be removed for cleaning. Do they unclip from the little gliders or do the gliders unclip from their runner (as they did on my Musketeer) or is it necessary to remove the runner end stop and slide all the gliders off?
I'm quite prepared to have a go at each of the above but I don't want to cause more problems by going about it the wrong way.
