I have read advice on how to do this on various bits of the Internet including on here. Most consensus appears to be to use white vinegar in a 50:50 dilution with water. Pump it into the hot water tank by the usual method. Then advice starts to vary:
1. Do you need to pull it all the way through to the taps or just enough so that it starts to spit?
2. What about the in line filter. Will this be OK?
3. Do you heat it up? Some sites say yes, but there is a post on here from Damien (whose advice I trust) who says don't as it foams up.
4. Anything else we should know.
Before anyone asks it definitely needs doing as the taps weren't running properly and the service guy said the gauze was all blocked up by lime scale. He has cleaned them out.
Thanks in advance,
Thanks in advance,
