Hi Jenn
Apologies for not seeing this post before you added another topic which I've temporarily locked to prevent the thread being scattered all over the forum before we've had chance to find out what the problem is on the original topic.
Are you using Internet Explorer 9 by any chance?
If so please
Click Here and follow the simple instructions to activate the compatibility function for this website.
If this is not the case, click onto your original topic and click on 'Disable Rich Text' which will be at the bottom left of the comment box.
Let me know if you can then read the topic.
Your original post was:
I would really appreciate your expert advice on something. My local council is planning to put a travellers' site at the end of the cul-de-sac I live in. The road is about 100 yards long, then a sharp left turn onto what will be the travellers' site. There are parked cars (residents' permits) along one side of the street, then a 2.6m metre width of road to the far curb, then a pavement which is only 96cm wide. The Council insists that traveller caravans will be able to access the site. However, they have based this on their belief that traveller caravans are only 2.2m wide. Our research shows that they can in fact be up to 2.55m wide. In each case, I believe wing mirrors would need to protrude another 0.5m in width, giving a range of 2.7m to 3.1m. In your experience, do you think it's possible to tow any caravan between the widths of 2.2m and 3.1m along the street, through a gap 2.6m wide, without damaging the cars on one side and putting anyone at risk on the pavement or emerging from their gardens on to it, on the other side?
Thank you in advance for your opinions.
JennMor'
I see that you have since asked if 'censorship' is being applied, no it isn't Jenn but you are probably a faster typist than I am so you fired off your comment before I've had chance to have a look, try to find out what the technical problem is and add my reply.
I can see your original, I'm using Firefox which seems to work ok on this website.
