Dometic 3 way fridge - 12 V switch problem
Nov 29, 2010
59
Last year the 12V switch was a little erratic. Start up the motorhome, switch to 12V operation and no red indicator lamp to show that it is working. Flick it on and off a couple of times and it would light up and the fridge would cool down nicely.
This year, no amount of switching will get it to illuminate. I don't think it is cooling either but have only done 15 mile runs.
I have done a few tests with the multimeter: There is no 12 volt supply when the engione is off - good. There is a 12 volt supply at the switch when the engine is running - good. Flick the switch but no red light coming on in the switch - bad. I did take the switch off and check resistance; when the switch is off there is indeed no connection through to the supplly pins; with the switch in the on state there is a connection to supply side of switch.
These switches cost £20 so maybe there is more to the switch than meets the eye!
Anyone any ideas apart from buy a new switch which is looking likely.
I am about to try running on 240Volts to see if it cools the fridge. Do the 12V and 240V use the same heater coil in the fridge, anyone know?
Thanks for reading
Nov 29, 2010
59
Just for information. Have checked the 240 volt operation and it works. Have also now tested the switch with a 12 volt bulb and a spare battery. The switch does the main switching job ok but the warning light in the switch does not work. I therefore presume the fridge will be cooling!
I have found a source for the switch at a price of about £13 at gwcaravanservices. Its part number 2926273505 in case anyone else needs one!
I wonder if I can replace the warning light bulb?
Nov 19, 2010
1,542
Light on ours comes on sometimes, but not always. However, I haven't bothered doing anything about it, as it always cools.
You can test that fairly easily - once you've taken it for even a short run, if you open the icebox you should find the element inside is freezing cold to the touch.
gjh
Jul 28, 2011
618
The 12v operation isn't always intended to cool the fridge down but, rather, to maintain a low temperature whilst travelling after it has been cooled using gas/mains.
I think the warning bulbs in that type of switch tends to be soldered into the circuit so, even if you could obtain one, the cost may well not be much less and it would be a hassle changing it.
Nov 29, 2010
59
Update: Bought a new switch and no change so it's not the switch, I had my doubts! Have run new tests on the switch and neon light does work when connected between poles of an old 12 Volt battery.
I have now gained access to the top and back of the fridge. I disconnected the 12 V heating element and connected it across the 12 volt battery terminal. Left it for 10 minutes and felt it (still in-situ) to check if it was warming. It was very hot!
So switch works and heater element works but not when in the van circuit. I took it for a run of 20 mins and it was stone cold (heating element)
I am now checking out the rest of the circuit to see if there are any bad connections.
Any suggestions welcome. (Taking it to auto-electrician is a last resort - not in my nature)
Nov 29, 2010
59
Found the problem. A burnt out connection on the feed from the power distribution board (behind the drivers seat if you have a CI Carioca 644.) Not sure why it got so hot. A poor connection would result in a resistance and some heat. The fuse on the circuit is still intact. Need to do an autopsy on the connectors.
I will replace the pcb board socket and fit a new plug when they arrive from Italy and then run some tests.
Aug 30, 2013
205
Hi, we have another friend in need of your tips on fridges here - a trouble shared is a trouble halved... and that's why forums can be so handy!
Tue, May 28 2013, 5:49AM
Teepee
Offline
The 3way fridge does not work on240 or gas it just won't
cool the pipes behind fridge are hot. I never use the 12v side so don't
know if that works, any advice would be very helpful. Thanks. Teepee.
516yuanyuan
BANNED
May 16, 2016
64
cartier watches for sale
ray ban sunglasses
new balance outlet
valentino shoes
gucci outlet
abercrombie and fitch
converse shoes
dior sunglasses
burberry handbags
oakley sunglasses,oakley sunglass,cheap oakley sunglasses,oakley sunglasses cheap,oakley sunglasses outlet,oakley store,oakley outlet,oakley outlet store,oakley sunglasses sale,oakley sunglasses discount
mizuno running shoes
reebok outlet
kate spade outlet
lululemon sale
longchamp outlet
ray ban sunglasses
rolex submariner
coach outlet store online
stephen curry shoes
toms outlet
kate spade outlet
levis 501
michael kors bags
designer handbags
louboutin shoes
cheap jordans
nike free runs
adidas supercolor
nike roshe run women
hollister co
yeezy boost 350
burberry outlet online
adidas trainers
coach factory outlet online
basketball shoes
chaussure louboutin
versace
omega watches
michael kors outlet
cheap air max
ray ban sunglass,ray ban sunglasses,ray ban outlet,cheap ray bans,cheap ray ban sunglasses,cheap ray bans,ray bans
vans outlet
louboutin outlet
ecco shoes
michael kors outlet clearance
ghd flat iron
sac longchamp
canada goose jackets
coach purses
coach outlet online
coach outlet online
adidas nmd
michael kors outlet
instyler max
oakley sunglasses wholesale
versace sunglasses
toms shoes
adidas nmd
prada outlet
adidas superstars
ralph lauren
air max 95
longchamp bag
chi flat iron
armani jeans
oakley outlet
reebok uk
true religion outlet
michael kors handbags
fitflops sale clearance
polo ralph lauren
lacoste outlet
cheap jordan shoes
ralph lauren outlet online
michael kors outlet
adidas nmd
nike store uk
skechers shoes
louis vuitton borse
rolex watches
ralph lauren uk
nba jerseys wholesale
christian louboutin
louis vuitton pas cher
nmd adidas
cheap nfl jerseys
sac longchamp pliage
yeezy boost 350
converse all star
hollister sale
michael kors outlet
burberry
ralph lauren outlet
lululemon outlet
oakey sunglasses wholesale
burberry uk
christian louboutin shoes
coach outlet
yeezy boost 350 white
pandora jewelry
michael kors outlet
adidas shoes uk
asics shoes
hermes belt
polo ralph lauren
kate spade outlet
yeezy boost 350
designer handbags outlet
lacoste shoes
adidas nmd white
toms shoes
supra shoes
bottega veneta handbags
nike air max
ugg outlet
supra for sale
gucci handbags outlet
polo ralph lauren outlet online
ray ban outlet
nhl jerseys wholesale
coach outlet online
michael kors outlet online
louboutin outlet
adidas pure boost
pandora charms
louis vuitton bags
cheap ray-ban sunglasses
michael kors bags
adidas superstar
cheap oakleys outlet
oakley sunglasses
burberry outlet
nike cortez white
nike trainers
nike air max 90
kate spade outlet
louboutin pas cher
nike tn
micahel kors
converse shoes
michael kors outlet
prada sunglasses
polo ralph lauren
hermes uk
cartier watches
adidas shoes
asics gel nimbus
mlb jerseys wholesale
converse
coach outlet
adidas stan smith
nike cortez
polo ralph lauren
louis vuitton outlet online
cheap jordans
air force 1
rolex replica watches
toms wedges
cheap ray ban outlet
polo ralph lauren
ed hardy uk
nike blazer
ray ban sunglasses
under armour shoes
christian louboutin uk
fitflop uk
coach outlet
jimmy choo shoes
nike huarache black
running shoes
cheap oakleys
jordan pas cher
valentino outlet
michael kors outlet stores
omega seamaster
fitflops shoes
ralph lauren outlet
cheap nike shoes
coach outlet online
coach outlet clearance
gucci borse
nike air max uk
michael kors outlet
ralph lauren pas cher
true religion
fitflops outlet
reebok shoes
ferragamo shoes
ghd hair straighteners
nike air max
cheap nfl jerseys
hollister
salvatore ferragamo
ed hardy outlet
wholesale nike shoes
ray ban sunglasses
true religion jeans
jordans shoes
adidas gazelle
nike huarache
michael kors purses
fitflops sale
vans shoes
jimmy choo outlet
ray-ban sunglasses
burberry outlet
yeezy boost 350 black
oakley sunglasses
fitflops sale
ray bans
oakley sunglasses
reebok
under armour outlet
ugg outlet
nike air max
bottega veneta
armani exchange
air jordans
michael kors handbgas
puma shoes
cheap jordans
babyliss flat iron
"Lowry scores 35, DeRozan has 28, Raptors beat Heat 116-89
TORONTO (AP) — Kyle Lowry scored 35 points, DeMar DeRozan had 28 and the Toronto Raptors beat the Miami Heat 116-89 on Sunday in Game 7 to reach the conference finals for the first time in franchise history.
Bismack Biyombo added 17 points and 16 rebounds for the Raptors. They'll open the Eastern Conference Finals in Cleveland against LeBron James and the Cavaliers on Tuesday night. Toronto fans chanted 'We Want Cleveland!' in the seconds.
Pause
Current Time 0:00
Duration Time 0:00
Loaded : 0%Progress : 0%0:00
Fullscreen
00:00
Mute
DeMarre Carroll scored 14 points, and Patrick Patterson had 11 to help the Raptors become the 15th team in NBA history to win two Game 7s in one postseason. Toronto beat Indiana in the first round.
Dwyane Wade and Goran Dragic each scored 16 points for the Heat. They were denied the opportunity to renew acquaintances with former teammate James in the conference finals
But after Toronto dominated the Heat in the second half and rode the superior play of Kyle Lowry and DeMar DeRozan to a 116-89 romp, the Raptors won the series 4-3 and advanced to its first East Finals. For once, they did not underachieve. They played like a team that had won 56 games in the regular-season. They’ve been in existence since 1995-96 and had been out of the first round just once before this spring. Before Sunday’s rout of the Heat, they had been mostly known through the years for losing big playoff games, often at home.
So Canada loves it, but basketball fans won’t be able to see the Heat try to exact some revenge against James for leaving Miami two years ago as a free agent. Even James admitted during the second-round series against Atlanta that he wanted to play Wade, his old teammate, for the right to get to the Finals."
dwfef
