Hi, We have a Bailey Pagaent Champagne fitted with a Dometic RM8500 fridge. Our problem is that the door catch sticks and is difficult to open, and we are worried that at some point it may become impossible. There appear to be 3 points to adjust it,
First the Door hinges, these seem to have some slack in them and if you lift the door while opening it it doesnt stick, Second the Catch in the door, although I can see no obvious way of adjusting this, and finally the clip on fridge body. This appears to be held in by two screws, but they are behind a clear plastic cover that I can't remove.
To get at the door hinges, which is my preferred solution I have to take the fridge out of the housing. There are 4 plastic plugs which look as though they cover screws into the casing , but a quick check found no screws. How do I get the fridge out? and will it be connected with flexible tubing so I don't have to disturb the Gas.
Any Ideas would be welcomed
Dave C
Dave C
