Good morning learned colleagues. Away at the moment and our 2015 Conqueror Dometic fridge has developed a fault. Out of the blue the red warning light is flashing and the fridge beeps 33 times. This repeats every so often, always 33 beeps. I understand this is the ‘door open ‘ alarm. The door shuts firmly and the light goes out fractionally before the door shuts. There is a two wire connection to the light and a simple on/off micro switch. I have cleaned both and sprayed with GT85. I’ve also tried disconnecting the plug to give a permanent door shut signal to any monitoring device. All to no avail. Tried running on gas, seems to be ok but our gas bottle is all but empty ☹. The fridge appears to be working still. I’ve heard that the early Command system😂 can interfere with the correct running of the fridge and it’s simply a matter of disconnecting. Obviously can’t get hold of Dometic at the moment but as my wife’s chemotherapy drugs are in the fridge and need to be kept cold it’s a bit urgent. I’m off to get gas in a mo but wondered if anyone has any advice to get it going on EHU again
