had my caravan in for some work this week and asked them to check out the gas system for the fire, i have never been able to work it. got a phone call yesterday from the garage and guy says the fire is working fine and can't see anything wrong.
anyway, brought it back home today and went about setting everything up, and couldn't wait till i finally had the gas working. huh, it was just the same, nothing at all.
i was almost on the phone back to the garage when i double checked the hand book diagram for the gas lines, sure enough there it was quite clearly in frony of me, white valve for the fire. i checked again and still nothing. looking at the branch of pipes and their colour coded valves i noticed that the green was indeed running to the hob, and the blue led to the fridge. ther white one which the book states is for the fire, and the red one which the book states for the water heater both run under the flooring at almost the same point. i thought i would give it a try to use the red valve then attempt the fire again, loh and behold, working fine. all along i have been using the valve as instructed by the handbook and taken it as gospel, just a wee bit info in case it happens to anyone else.
