EC400 PSU possible charging problems
Aug 16, 2021
My recently purchased 2012 Swift Challenger Sport 524 is fitted with a Sargent EC400 Power Supply Unit. On my first trip away with a fully charged reliable battery the LED display showed 13.5v.
After 4 days the LED display was down to 11.5v so to double check I disconnected the battery and with a voltmeter measured 11v. I then switched the charger back on and got a reading of 14v from the battery charger leads.
On reconnection the LED display showed 13.5v but after 2 days was back down to 11v reading.
When I returned home I conducted all the tests that the Sargent Technical leaflet suggested and all results were as per specified.
The question is, do I have problem with the charger that is difficult to diagnose as I would assume that with little overnight battery use it should come up to full charge?
Thanks in advance
935
Did you have the charger on all the time you were using the van?
