Hi there, caravan purchased 3 years ago, I looked up pressure for model assuming tyres were correct, it's only today I happened to notice so I could be in a spot of trouble getting them to sort this far down the road, but will try.
Even the spare is 175 I now wonder if this is the correct size and online manual is in doubt as tyre size for all models is 185. As long as safe as are correct rating then maybe someone has an idea if 60 psi is still applicable for this width
I changed the width on a Bailey to accommodate an increased load when the caravan payload was upgraded. But I went the reverse direction to you. You should check their Load Index and make sure it’s sufficient for the caravans maximum load as a minimum. Also a margin of 10% is often cited to allow for inadvertent overloading.
What age are your tyres. If you have had the caravan fir three years they may require changing as advice is 5-7 years from date of manufacture. That’s on the side wall.
Hi looking for some advice from Swift group perhaps. My 2004 Sterling Eccles Amythyst MTPLP 1489Kgs has Hankook 175/14 tyres 99/98 load.I wish to replace with 185/75R14 from the same manufacturer which have a load index of 10/100.According to Hankook the actual sizes of the tyres, dia.etc are...
forums.practicalcaravan.com
This old thread may be of use but without seeing the OP handbook😉
