Elddis Avante 624 rear light cluster
Aug 3, 2015
Help needed, indicator bulb failed and I can't get at it to change it.
The light cluster is a vertical mount. One screw allows the indicator part of the cluster to partially swing out but not all the way.
If I push hard it feels like I will snap the indicator unit.
No information in instuctions.
All suggestions greatly recieved
Read more at http://www.practicalcaravan.com/forum/new-members-say-hello/51558-elddis-avante-624#9KGUolirFiMuRSRK.99
Aug 25, 2014
28
I wonder if you can take the screw out, pull it toward you slightly and then down? The top of the light may go up behind the panel hence no need for a screw?
Hard to see without seeing it.
