Good or bad?
Sam’s seems happy with his too, but no doubt disappointed with it being affected by damp. But that’s caravans for you, be they old or new. Every caravan I’ve owned has had damp some sorted under warranty, the rest down to me. Fortunately I’ve always kept up with servicing and damp checks and any damp has been caught relatively early. But it’s still darned annoying and at times gut wrenching.Thanks OC was going to say. Thought it was Mel who loves hers but wasn't 100% sure.
Are you sure those years were Eldiss Solid bonded construction? Why does any commodity maker change the model range? ProbaBly not enough being sold and like small cars not sufficiently profitable compared to larger higher spec models.Thank you all for your replies, I am looking at 2011/2012 vans and what I wish to know is how reliable and damp free the vans are as I believe the 302 was bonded and not screw and mastic in its construction.
Also why did they stop production?
Many thanks
Mike
Well i would check it out see if it got service history take a damp meter with you i use own a Elddis caravan it was a sound and like what someone says there are are some members who own them on hereThank you all for your replies, I am looking at 2011/2012 vans and what I wish to know is how reliable and damp free the vans are as I believe the 302 was bonded and not screw and mastic in its construction.
Many thanks
Mike
Yes it’s me. We do love it. It is a 2013 model. They stopped making them after that. It is a tiny van but the L shaped lounge makes it feel spacious. There is a lot of storage for such a small van, but we also think carefully about what we take . We keep the bedding ( double duvet, panda mattress topper, and 4 pillows) in the wardrobe. There is an art to it but it does all go in. Build quality seems good, although there is currently the spectre of localised damp in the near side rear corner. First time we have had damp. ( I am told that this is sometimes an issue with the 302)Thanks OC was going to say. Thought it was Mel who loves hers but wasn't 100% sure.
Don't get confused by the description of "bonded" construction. Prior to bonded construction, the wall panels had wooden frames to keep the inner and outer surfaces apart, and the gaps were filled with an insulation material all of which was assembled from the base materials in the factory. The common problems were leaks at joints , and the effect of having a leak could easily cause the wooden frames to start to rot.Thank you all for your replies, I am looking at 2011/2012 vans and what I wish to know is how reliable and damp free the vans are as I believe the 302 was bonded and not screw and mastic in its construction.
Many thanks
Mike
i might have to agree with you when we got our Elddis caravan the dealer went in great lengths about it Sold construction proven chemical bonding to replace more of the screws and bolts that is why we brought it for a Seasonal caravan .I'm not sure you're right Prof. In Elddis case bonded means screws have been replaced by glues. But wood frame is still the internal structure and up till this year all had ply inner lining aka old school. But this year Bucs have gone composite inner lining. However since this has been used for years it's tried and trusted . The floor is however protected unlike the bare ply of Bailey's. I spent our Bailey ownership worrying about floor rot and now have the opposite with our Buc! However we love it! It's certainly not flimsy. Not by other modern caravan standards any way. One reason we bought it tbh was that it didn't have bits falling off the demonstrator as some we looked at
Sandwich construction, introduced around 1980 is a bonded construction - the layers of aluminium/foam/plywood are bonded together under pressure - with wood inserts included around openings and for fixing points. For several decades, caravans had bonded floors, walls and a loose-skinned roof but recently most switched to using bonded construction for the roof as well.I'm not sure you're right Prof. In Elddis case bonded means screws have been replaced by glues. But wood frame is still the internal structure and up till this year all had ply inner lining aka old school. But this year Bucs have gone composite inner lining. However since this has been used for years it's tried and trusted . The floor is however protected unlike the bare ply of Bailey's. I spent our Bailey ownership worrying about floor rot and now have the opposite with our Buc! However we love it! It's certainly not flimsy. Not by other modern caravan standards any way. One reason we bought it tbh was that it didn't have bits falling off the demonstrator as some we looked at
Thank you for the update on the construction. My comments were designed to be more general than specific to a particular manufacturer. If your insight is correct then it would seem that Elddis "Bonded" construction can still be a rot nightmare.I'm not sure you're right Prof. In Elddis case bonded means screws have been replaced by glues. But wood frame is still the internal structure and up till this year all had ply inner lining aka old school. But this year Bucs have gone composite inner lining. However since this has been used for years it's tried and trusted . The floor is however protected unlike the bare ply of Bailey's. I spent our Bailey ownership worrying about floor rot and now have the opposite with our Buc! However we love it! It's certainly not flimsy. Not by other modern caravan standards any way. One reason we bought it tbh was that it didn't have bits falling off the demonstrator as some we looked at
By all means take a damp meter with you , but before you start probing with it you must seek permission of the owner.Well i would check it out see if it got service history take a damp meter with you...
I'd love caravanners to veto buying UK caravans to make the point very clear to the manufacturer's that they have to accept liability for poor construction and really do something about preventing the errors that so often plague caravans.
The majority of people do not have an issue with damp, poor quality etc. It is the minority that are vocal for good reason when there is an issue with their caravan and then post on forums of groups. Same applies to any other goods.Thank you all, so much appreciated. It looks like I will buy a tent or not.
Can I ask how does the Freedom van do?
Strangely enough I took the similar decision when I sold the caravan in June. The tent had to meet the dogs approval though. Apologies for the rough erection but it was a quick check as I bought this tent on EBay less than a year old, never used and less than half price. The first one I bought was a little too small to sit up in comfortably. Had two nice short breaks, but no longer a 4 seasons tent camper.Thank you all, so much appreciated. It looks like I will buy a tent or not.
