Aug 29, 2007
8
Wonder if you could help ? I have a Tabbert Jeunesse 515 HTD 2000 model and have a problem with the electrics. When plugged into mains i have 240 volts in van but have no 12 v circuits working ie lighting , toilet water pump, water tank .What would you think could be the most likely cause ? The battery , as i don't think it's ever been changed or the charger or even a problem with the fuseboard ? With it being German i'm struggleing to understand the wiring. The indicator light on the panel took an age to go green also but the charge indicator shows it charged ..........HELP ....!!
Will any type of 110 AH battery do or is there one recommended if it is that ?
Feb 7, 2008
42
David,
Have you got 12v without the mains hooked up?
David,
If you have 12v without the mains hooked up its probably the inverter and may cost a few bob to renew.
If you have no 12v in either case its probably a fuse and most likely the in line fuse to the battery. Don't know anything about Tabberts but it is probably behind the battery box.
I had a similar problem with my Sterling and fortunately it was the fuse.
Good luck.
Feb 7, 2008
42
David,
David,
Good luck.
oops, sorry, too many Davids in that last message!
Aug 29, 2007
8
David,
David,
Good luck.
Hi John thank you for your reply but we do not have any 12v supply even with main hooked up.
