The absolute worst part of RVing or Caravaning is when you take a shower in such a small space that the shower curtain always sticks to you, and when you turn around it wraps you up, causing water leaks on the floor. A new product called Expandable Shower Curtain does away with this problem altogether. What a difference when taking a shower! It gives you so much more elbow room that its just like being at home in your own shower. It was so easy to set up and use. You just pull the line with an attached ring and the shower curtain billows out real big. Then, attach the ring to a hook on the opposite wall. When you are done, you just remove the ring from the wall hook and the curtain hangs straight in the tub again. I would highly recommend this to anyone who RVs! I bought in online at www.campingworld.com. You can view it online and see how it works by typing in Expandable Shower Curtain at the search box.
David B. Bathurst
David B. Bathurst
