Extra security idea
Aug 4, 2007
67
Hi, message from husband, he has drilled a hole through the female part of the tow hitch and puts a heavy padlock through it when he unhitches the van. This means that the tow ball won't go over it. This as well as the wheelclamp, makes him feel safer. Anyone else tried this or is he a genius?
May 10, 2007
257
High Carole.
I think he may have rendered the tow hitch illegal as it will have "type approval". I guess it may no longer be considered fit for purpose bye an insurer should you have an accident!
An approved tow hitch locking ball that fits in the hitch may be a smarter move and be harder to remove than a padlock.
Ria
Apr 13, 2005
1,210
I did not think there was type aproval for the hitch, i thought it was just the tow bar fitted to cars that needed type aproval.
but having considered the modification i can see that it may well render the hitch less able to take the forces applied during a journey and could be seen as dangerous so i would join ria and james in my thinking that you may just have made your van not quite within the specifications laid down by law, (for want of a better quote).
I would check it out with the relevant forces just for peace of mind, One thought though if the scum bag t****s can cut off a gold secure hitch lock how better do you think your padlock will be ?.
May 21, 2008
2,463
I would be very carefull before dashing out with your drill in hand.
Not only could you invalidate type approval, but you would open yourself up for your insurance company to dump you faster than a hot potato.
However fitting additional locking devices is a good idea. For instance, I use one of those brass barrel locks that fit in the handle of the hitch on my goods trailer and lock the bulldog hitch lock base plate in place in the hitch, then I lock the bulldog head as normal. Should the light fingered brigade try to get thelock open and succeed, they are then faced with another obstical. All of which cost's time and that is one thing a thief doesn't have on his hands.
I was appauled when a couple of years ago, PC ran an article on security and proudly displayed photos of the tools of the trade for thieves. Namely the "drop box" which is used to negate the need to bother to remove the hitchlock. Any budding criminal was given a detailed picture of the design and a written description of how it worked.
It is a fat of life these days, that the more inconvienient you make it and the more time consuming it is for the thief, the more likely they are to move on to easier pickings.
I can recall one person who was glad to be a keen gardener. One night thieves got past the wheel clamps (2) and hitch lock on his van and even managed to quietly take two 6ft fence pannels down. But were thwarted when the caravan sunk upto it'a chassis as they pulled it over the freshly dug flower bed. All the chap knew about it was when he went to go to work, only to find his caravan blocking the road.
You see a thief will go to any length but the more difficult and time consuming you make it for them the better.
Steve L.
Nov 1, 2005
1,001
We once lost the keys to the hitchlock on our car transporter.
Armed with a battery drill, a large flat screwdriver and a hammer we removed the hitchlock just about as quick as we could have unlocked it.
A padlock could be removed with a crowbar in about 5 seconds.
On top of that, if your hitch requires the ball to be greased you'll end up with grease everywhere after a trip, it'll come out the hole.
