Finally finished the repairs... Small crack on the lower front where I repositioned a planter! and the front fairing where I stupidly stowed the nosewheel facing the wrong way. The repairs were fairly simple. As both panels were plastic I stop drilled the cracks both ends. Drilled several small(2mm) holes either side of the crack along it's length and opened up the crack slightly. Repaired using isopon plastic bumper repair paste before rubbing down with progressively fine wet&dry. Plastic primer then finished with car paint. Had to have two tries before I got a decent match but still not quite right. How can I find a colour that matches? Van is Avondale Dart (2008).
Also solved the prob with damp in the outer wall of the shower/toilet. I knew it had to be getting in from the outside as the shower has never been used. Took out the inner wall and oh dear. My guess is that it has leaked from new. Tracked it down to the rail accross the back(top) of the roof - joins the roof to the back panel. Once removed it was obvious that was the culprit. Hardly any sealant on the off side. Cleaned, dried and resealed with sikoflex. With inside panel out for three weeks no sign of any further leaks despite torrential rain. Treated all the wood with hardener and replaced a couple of pieces. New panel in and sealed back up. Looks as good as new.
Thanks to Wincanton mobile caravan repairs for help and supply of panels, adhesive/sealant etc. Cannot praise too highly.
But how to match the paint????
