fitting a towbar
Can anyone help me I've just purchased a witter towbar on ebay and I need a bit of help as to where to wire the twin electrics to on my vauxhall cavalier sri hatchback. Any help would be greatly appreciated.
If you don't know exactly what to do then I suggest that you ask a towbar fitter to do it. The wiring will take a professional about 30-60 minutes.
Hi
Take the wiring into the boot area aroung the ns back light.
7 core wire with the black casing - black socket is your lights etc. Wire it up as follows-
Yellow - LH indicator
Blue - Fog Light
White - Earth
Green - RH Indicator
Brown - RH Lights
Red - Brake light
Black - LH Lights
You will need a flasher relay from Halfords etc - just follow the instructions in the pack as each one varies- should cost around 15.00
Grey wire 12s socket
Yellow - Reverse lights
BLue & Red - Split charger
Green - 12v permanent supply
Black - Earth
White - Earth
Brown - Not used
