Fitting a Whale tap, Easy?
Dec 6, 2007
414
Hi
I've got to fit a new Whale tap to the filp-up sink in our 1994 Elddis.
My main worry is how to remove it from the sink, there are little round plastic plugs at the corners, do they hide screws? Or are they retaining pins? How easy are they to get out?
Any advice would be most welcome
Gareth
199
19,235
Yes - they're plugs. Use a sharp, strong needle to flick them out. Screws underneath. Try not to damage the surface of the plugs.
Dec 6, 2007
414
It was easy!
Except for me loosing one of the pipes behind the sink unit!! Finaly managed to remove the whole pipe & feed a peice of rigid plastic pipe through then use that to pull the hose back through.
If you do one of these, DON'T LOOSE THE ENDS OF THE PIPES!!!
Gareth
