fixing a solar panel to roof of caravan.
Nov 7, 2006
136
Can anyone please tell me how do you go about fixing a solar panel to the roof of your caravan, we have been considering this and as we like doing the rallies it sort of makes sense to have this done. Also can you do it yourself or do you need an experienced person to do the job. Can you tell me if this method works well or not as well. Thanks.
4,127
1,860
Part answer:
flat on the roof in the UK ought to return reasonable yields in the summer months as the optimum angle then is about 15 degrees to the horizontal.
However in the winter the optimum is nearer 50 degrees and as the hours are shorter the flat on roof will not yield very much.
A free standing can be tracked and its angle adjusted giving much better winter and marginally better summer yields but its often a pain.
You need to be able to keep it clean as any blanking/shadows etc have a very adverse affect on yield.
Feb 28, 2009
493
Erica,
Go to www.aireandsun.co.uk they do a kit and complete instructions for fitting a panel to the roof.
What JTQ says about panel angles is correct but I find in practice with the panel on the roof it is charging from the moment the sun rises and not from when you decide to put it out(and keep moving it).
Also are you going to leave it out so the local thieves can get their hands on it when you go out for the day.?
Its the difference between theory and practice and you will have to make the choice.
I have been very surprised at the total amps my 65w panel can put into the battery during the course of a full summers day.
I have been very pleased with my choice
Jim
Just got back after 14 days away, 3hours a night sat & telly no probs with 85w on roof. Go for a kit as has been said. Yes you will lose out in the winter when you need it most,but not as much as having to stay in all day to move it every hour.
Nov 7, 2006
136
Thanks to everyone for their replies. Putting the solar panel on the roof certainly sounds the best, at the moment we have it on the ground on a stand, but everytime we go out we do wonder if it will be there when we get back in. Winter no problem has we dont rally in the winter usually have hook up. Once again thanks for your replies.
Aug 23, 2009
3,167
To get the best out of a solar panel, and we too rally most weekends all year round you should have it at a 45 degree angle. I wouldn't have a roof mounted as you will need one twice the size for roof mounting
Nov 7, 2006
136
Hi Martin, thanks for your reply. My hubby says he now prefers the solar panel on the ground using the stands, mainly because we have 2 panels linked together. He thinks it would give us more chance of getting sunshine from the stands. We just love the rallys. Going to The Bodafon Field rally at Llandudno next outing. We always rally with Camping and caravan centres. May see you there if your from the North West. look out for a disabled volkswagon van and 4 dogs. We sort of stand out somewhat. Dont be put of though we are quiet people with quiet dogs. best wishes. Erica.
Aug 23, 2009
3,167
we may see you around but tend to stay local in Yorkshire most weekends, do most of our rallies with our owners club and TCC. We are everyone's nightmare, Child and Dog. still used to be child and 3 dogs!
4,127
1,860
hi just joined the forum
take a look at this site i found for diy fitting of solar panels.
http://www.1carpc.co.uk/wcdr/new-page-2.htm
i fitted two 40 watt panels to the roof of my caravan wired to a regulator and then to an 85 amp battery, we did five weeks around july - august time, touring north wales mostly without electric
Its okay until there is an "iffy" electrical connection under the panel, you try undoing Sikaflex 291.
JTQ,
If a proper fitting kit is used, then the panel can be removed leaving the brackets bonded to the roof.
My DIY method is to mount aluminium angle on two sides of the panel with stainless steel self tappers, then bond the angle to the roof with Sikaflex.
I then replace two of the ss screws with aluminium pop rivets to deter theft. These rivets can be easily drilled out if maintenance is needed.
4,127
1,860
JTQ,
Rod, a much better method.
The "link" unfortunately showed a technique that made maintenance impossible and so is not a good recommendation however visually neat and tamper proof. Very tamper proof indeed!
Cheers JTQ
Nov 10, 2009
8
The original question was how is it done and could it be done by them?
This site shows how the panels are wired using a charge controller and gives a basic idea of what is involved.
The fixing brackets are down to you, from home made to shop bought, but the equipment used and the wiring and use of a charge regulator still remain the same
Erica, good idea we have a solar panel 45W and it keeps the battery charged without much problem. I fitted my panel with the large suckers that are avialable from caravan shops originally to fit on the ends of awning poles, i pass the panel out through the helki and it sticks well on the roof out of sight of every one. Hope this helps, Bazz.
Nov 7, 2006
136
Bazz, Thanks for your reply we liked your method and are now planning to try to do the same. Good idea about the suckers from awning poles. My hubby going to try doing the job when weather improves. Once again thanks. Roll on summer and the start of the new season. Decided not to go in winter but getting itchy feet badly.
chenzhen
BANNED
May 19, 2016
99
"The word vintage, used to describe dresses and clothing, is a broad term that is generally used to refer to clothing that originates from a past era. In general, clothing that dates earlier than the 1920s, is considered to be antique. Whereas clothing and dresses that have emerged after the 1920s, up to the 1980s and 90s, is considered to be vintage. Retro, or vintage style, usually refers to clothing that is an imitation of the style of a previous era.
A range of vintage style clothing that is hugely popular today, are the fifties dresses. The enduring popularity of these dresses, might be because that was the time women's clothing made significant strides, as it was after the second World War and many restrictions had been lifted and designers had more freedom and materials available to create beautiful women's fashion ranges.
Some of the popular dress styles that have enjoyed a timeless appeal have included the Ophelia dress, floral tea dresses, Audrey Hepburn style dresses, the figure hugging Lindy Bop dresses and dresses made famous by Grace Kelly and many classic Hollywood stars. Even today, young women are choosing vintage style dresses for their special occasions such as a ball, prom night, and other formal parties, because they have a definite charm and elegance and have been designed to enhance a woman's shape and beauty."
fake oakleys
michael kors uk
cheap ray bans
rolex watches for sale
nike free flyknit 5.0
ugg boots
coach outlet online
yeezy boost 350 white
michael kors bags
air max 90 white
ralph lauren outlet
louis vuitton bags
converse sale
coach factory outlet
adidas shoes
nike free flyknit 3.0
burberry outlet
nike air force
cheap ray-ban sunglasses outlet
tory burch shoes
nike tn pas cher
chaussure louboutin
adidas nmd runner
louis vuitton handbags
skechers outlet
oakley sunglasses cheap
cheap jordan shoes
ray bans
adidas nmd black
reebok classic
adidas trainers
vans store
nike cortez white
pandora charms
air max 90
adidas shoes
fitflops shoes
timberland uk
pandora charms uk
armani exchange
burberry bags
under armour
louis vuitton outlet stores
oakley sunglasses wholesale
pandora jewelry outlet
cheap basketball shoes
ferragamo
ralph lauren
pandora rings
toms outlet
michael kors outlet online
prada sunglasses wholesale
cheap ray bans
www.coachfactory.com
cheap air jordans
michael kors handbags
valentino
michael kors outlet clearance
michael kors outlet
ugg boots
ralph lauren
ghd
mizuno running shoes
nike air force black
cheap jordans
nike free run flyknit
cheap ray bans
sac longchamp
kate spade outlet
cheap ray ban outlet
ray bans
true religion jeans
babyliss hair dryer
michael kors bags
true religion outlet
reebok outlet store
ray bans
nike trainers
polo outlet
fitflops
adidas superstars
true religion outlet store
kate spade uk
discount nike air max
ray ban sunglasses outlet
jordan pas cher
levis 511
nike huarache
omega speedmaster
christian louboutin uk
michael kors outlet store
tiffany jewelry outlet
polo ralph lauren men
adidas supercolor pink
rolex replica watches
ray ban outlet store online
cheap nike air max
coach outlet store online clearances
tory burch flats
hollister hoodies
nike cortez shoes
louis vuitton outlet online
hollister hoodies
pandora jewelry
louboutin outlet
coach factory outlet online
adidas pure boost black
designer handbags wholesale
yeezy boost 750
true religion
kate spade outlet online
tiffany uk
lebron james shoes 12
red bottoms outlet online
cheap jordan shoes
jordans
gucci borse
gucci handbags outlet
ray ban sunglasses sale
lacoste shoes
bottega veneta shoes
michale kors uk
ray ban sunglasses discount
louis vuitton uk
cheap ray ban sunglasses
longchamp outlet
micahel kors
adidas superstar white
air max
cheap nfl jerseys
burberry outlet
christian louboutin outlet
hollister clothing store
oakley sunglasses outlet
ralph lauren
nike blazer
michael kors canada
birkenstock sale
cheap ray bans
white converse
louboutin pas cher
jimmy choo
ed hardy uk
bottega veneta sale
north face outlet
nike air max 95
burberry sale
abercrombie and fitch outlet
hollister kids
louis vuitton purse
supra outlet
nike huarache black
nmd adidas
asics running shoes
lacoste polo shirts
jordan shoes
michael kors canada
abercrombie & fitch
coach outlet online
tiffany jewelry
burberry outlet canada
ray ban sunglass,ray ban sunglasses,ray ban outlet,cheap ray bans,cheap ray ban sunglasses,cheap ray bans,ray bans
ralph lauren outlet online
canada goose outlet
mlb jerseys wholesale
vans outlet store
birkenstock sale
coach purses on sale
ferragamo outlet
valentino bags
rolex submariner
mont blanc outlet
hollister co
nike air force
the north face outlet
armani outlet
tiffany and co outlet
michael kors handbgas
cheap oakleys
north face jackets
dior sunglasses 2016
coach outlet online
north face uk
kate spade bags
polo ralph lauren outlet
ray ban outlet online
adidas nmd uk
ghd hair dryer
jordan shoes
hollister uk
michael kors uk
buy red bottoms
nike roshe run
kate spade outlet
toms shoes
cheap oakleys
louis vuitton factory outlet
polo ralph lauren outlet online
puma outlet
true religion uk
chi flat iron
fitflops sale clearance
true religion jeans outlet
michael kors outlet canada
michael kors outlet
oakley sunglasses
instyler max
true religion jeans
fitflops
fitflops shoes
polo ralph lauren
pandora sale
michael kors outlet stores
hermes outlet
cheap oakley sunglasses
nhl jerseys wholesale
toms outlet
longchamp uk
timberland shoes
asics gel kayano
michael kors outlet
ed hardy
polo ralph lauren
versace sunglasses wholesale
louis vuitton borse
kate spade handbags
new balance shoes
versace sunglasses
birkenstock outlet
oakley sunglasses,oakley sunglass,cheap oakley sunglasses,oakley sunglasses cheap,oakley sunglasses outlet,oakley store,oakley outlet,oakley outlet store,oakley sunglasses sale,oakley sunglasses discount
michael kors bags
birkenstocks
nike air max 90
timberland boots for men
kobe bryant shoes
adidas shoes
birkenstock shoes
christian louboutin shoes
under armour outlet store
rolex daytona
michael kors outlet
abercrombie outlet
birkenstock uk
cartier
omega
polo ralph lauren
true religion sale
burberry outlet stores
nike shoes for cheap
nike store uk
sac longchamp pliage
nike force 1
ecco outlet
coach outlet online
louboutin shoes
canada goose jackets
nike free runs
reebok
converse outlet
coach outlet online
stephen curry basketball shoes
hollister kids
jimmy choo outlet store
nike air max 90
hermes belt
louboutin shoes
supra store
stan smith adidas
toms outlet
rolex watches uk
wholesale nike shoes
gucci outlet online
yeezy boost 350
nike free 5.0
cheap nfl jerseys
reebok shoes
coach outlet online
coach outlet store
tiffany and co jewelry
timberland shoes
ray ban outlet
timberland boots on sale
cartier love ring
white converse
louis vuitton purse
air max 90
ralph lauren pas cher
air jordan shoes
prada handbags
michael kors canada
holliste sale
adidas gazelle
nike flyknit racer
oakley sunglasses uk
yeezy boost 350 balck
lebron james shoes 2016
ralph lauren outlet
nike running shoes
kobe 11
nba jerseys wholesale
coach outlet store
michael kors handbags outlet
hollister clothing
louis vuitton pas cher
ralph lauren sale clearance
cheap oakley sunglasses outlet
"One of the most popular, but simple fifties dresses, is the petticoat. This was designed to be flattering to a lady's shape and also, to enhance the dress she was wearing over it. Petticoats made of silk and woollen materials were initially introduced for women to wear under the main dress, as they provided warmth and would enhance women's busts. The classic petticoat then became shorter and lacy petticoats became the fashion, as they delicately accentuated the dresses that were worn over them, such as the Ophelia dress.
Vintage style dresses UK are available in a wide variety of sizes from vintage clothing shops, textile fairs, auctions, flea markets, estate sales, antique markets, garage sales and collectable fairs. However, there is always the risk with buying genuine vintage clothing, that the sizes may not match current clothing sizes. But there are a number of special boutiques online, who specialise in designing and creating vintage clothing to order. They can take your specific measurements and produce an outfit that will be tailor made and fit you perfectly"
SGSDGDG
