Hi
My parents have a 1998 Elddis Hurricanme GTX which they bought recently. The van is pretty much immaculate throughout but on its first test run today, they noticed that when the left hand indicator is on and the brake light is on, the brake light flashes. With the brakes off, the indicator is fine and when the indicators are off, the brake light is fine.
To me this sounds like a suspect earth connection somewhere. They have checked the connections in the light cluster, and at the front of the van and they seem to be good.
The question is, does anyone know if there are likely to be any junction boxes somewhere in between the light cluster and the connections at the front of the van? It is very difficult to see, as the wires enter the plastic moulding at the back of the van through a small hole, and there is no access to the rear of this panel from inside the van to see what happens between here and the cable conduit running underneath the van. Will both rear lights have seperate cabling (including earths) from the main junction box at the front of the van or are there some "hidden" connections that need to be checked elsewhere?
Many thanks for any advice offered.
David
David
