Fleetwood Coulchester 520/4EB 2004
Jul 28, 2011
41
I have just replaced our 1999 Swift challenger with the Coulchester, Wow what a van :)
I dont however have a hand book and for all I have worked most things out I am still abit unsure with the water heater/temp and the central heating if anybody could help?
Also any opinions on the coulchester would be great please
Apr 20, 2009
5,569
949
Hi lishka, I had the same problem when I brought my Fleetwood Sonata, re the Handbook.
Email Allan and Jackie at; fleetwoodownersclubadmin@googlemail.com they will if they have a copy send you a CD version for about £10.00 of which you can then print out.
Mine does'nt have central heating so cant help with that one.
The controls to my heater are under the front right (looking from inside) seats, one for the gas of which you turn and adjust for water temp, when switching on you should hear a click which is the burner igniting, make sure you take the cover off each time outside, if using gas and keep the window above it closed
The electric side of it is just a switch.
Hope this helps.
2,399
Hi Lishka
Welcome to the Practical Caravan forum and congratulations on buying your Fleetwood Colchester.
It's best to ask your questions in the General section of the forum so that they will be seen by more forum members.
