Brought the caravan out of store for a trip away but I’m having problems with filling the water system for sterilising. . Initially the Flojet pump started up fine and water started to flow from the taps. Then it went dead. I moved the tap heads (3 ) thinking it might be a micro switch but pump still dead. Toilet flush ok which comes off same fuse. Anyway I removed the fuse and cleaned it but it was fine. So then disconnected the two pump supply wires and checked for voltage which was there. Pump has been removed now to see if it has any internal stiction or anything preventing rotation. I also removed the bottom electrical cover and checked the two spade connectors but they were clean and tight. If that is fine what other things should I look for. Never had a Flojet before.
Picture below:
Picture below:
