Hi Folks,
Could somebody please help, I have the above pump installed in my caravan and its worked fine for years. When we came to use it this time it would not turn on, and after investigation the 7.5amp fuse had blown, simple. But stupidly I tried to just change the fuse without isolating everything and as I did it shorted instead of just pushing in and and starting to work. So I now have an error code as E1, which I thing means something has shorted. If I take the fuse out the error message does not show. Now I have the task of finding what is causing this error and to try and get it working. I've read motor fail issues could be any of these, Loose wiring, pump circuit has no power, blown fuse, pressure switch failure, defective motor. Is there some other fuse on these things other than the standard one marked 'pump' on the standard fuse box.
Many thanks for any help
Hotchy.
Hotchy.
