I am shortly going to replace my gas locker floor as it is starting to crumble because its wet. Question is where do I get the foam/plywood sandwich stuff to do it with. If its not easy to get then I may just do it with with 18mm ply.
On that basis I would use the ply I have. Sadolin is a water based black paint ideal for wood products which are going to get regularly wet (roof fascias etc). It allows wood to dry out quickly which is much more effective than trying to seal it, as the sealants are never 100% (but once the wood is wet it cannot dry because the sealant will prevent it) Before you fit the 12mm ply, weigh it and the original and check the weight difference. I would like to know. By the way, what caravan is it?Floor removed its plywood/foam sandwich not formed plastic. I have enough 12mm ply in garage to replace it once I cut it out and weather proof it.
Go to a DIY shop,then treat it yourself if necessaryI am shortly going to replace my gas locker floor as it is starting to crumble because its wet. Question is where do I get the foam/plywood sandwich stuff to do it with. If its not easy to get then I may just do it with with 18mm ply.
