fridge defrost
May 15, 2007
471
As we were going away last weekend i put some food in the ice box. I went to the van this afternoon and it had all defrosted even though the fridge was cold with ice in the fins. By the way the van is on the drive with electric on all the time. Could it be something to do with the cold weather, i have now put winter vents on to see if this helps. Any ideas ??
936
If there was ice on the cooling plate that is the problem, the fridge sensor is encased in ice and thinks it is really cold, so switches off.
You should never allow ice to build up on the cooling plates.
May 15, 2007
471
Thanks Damian Think i must have overfilled it , or should i say somebody overfilled it, i can never understand why there is so much in the fridge when we get home , strange that eh.I think if we ate all that someone takes i would be about 50 stone by now.
Mar 29, 2005
405
if the fridge is full it will struggle to keep up and the setting should be on 7.if your fridge door is open slightly it will freeze up without getting the fridge cold because it does not switch off and warm air is getting in past the seals.
