Fridge LED
Mar 30, 2006
37
We have a 2006 Swift Challenger 540. The blue LED on the fridge control panel has stopped working, although the fridge still appears to be working fine.
The potential problem here is that the LED is the indicator of problems and either shows a steady light or flashes indicating something wrong.
Is it easy to change the LED or is it a dealer job ? and indeed Is it possible to purchase the required part ??
any suggestions or help with this would be greatly appreciated.
Thank you for taking the time to read this.
Kind regards
James
Mar 10, 2006
3,266
46
james
just a long shot. Have you tried a technical tap or two near to the led. This may indicate a dry joint?
Changing the led may be more trouble than its worth, depending on how accesible it is.
If you decide to change it, you need to fit the correct voltage rating, obviously it need not be the same colour, red being more common.
Hi James,
We had the same problem with our Thetford fridge. The pcb behind the fascia had to be replaced under warranty. From what I saw the replacement was very easy.
Andy
Mar 30, 2006
37
Hi James,
Andy
Hi Andy
Thank you for that mate. I contacted Thetford today, and they are sending me a new board, and explained how to change it. It seems dead easy.
I am so used to paying for everything, I never thought of enquiring about the warranty - stupid me or what ?
They were very helpful at Thetford, and no quibble at all.
Thanks again, and have a happy 2009 season.
Kind regards
James
Mar 30, 2006
37
james
Hi Ray
Thank you for your help here. As Andy says though, it needs to be the whole pcb and they are sending me a new one under warranty.
Have a good season in 2009 my friend
Kind regards
James
