The fridge on our caravan is not working on gas, it is fine on electric. The caravan was recently serviced and the we thought the problem had been fixed, however it is still not working. The pilot light is on but the fridge is not getting cold.
Thanks for the advice. The flame I can see is the blue one as you describe. I'll get in touch with the service centreHello d,
These multi fuel fridges all work on the absorption principal where to make them work you actually have to heat part of the refrigerant system. This means you can have gas, mains or 12v heat sources.
The good news is that if it works on one fuel type, it proves that the refrigerant system is intact.
You say the pilot light is on, and for clarity are you referring to a visual sight of the flame through the transparent plastic rod? - if so then it should be a nice irridecent blue flame.
The flame you see is not just a pilot, it is the main flame, and if it is present, and the fridge is not working then something is wrong in the burner area.
As with all gas appliances all installation, service, repair or removal must be carried out by a competent person working to the gas regulations.
I think you need to referthe caravan to your service centre.
