Look, the problem here is fixing a faulty fridge, the point being missed is, fridges are not quite as straight forward to fix as is presumed?
For a start, the thermocouple is probably the least likely reason, it don't matter then if it's only a tenner and 'easy' to change, it's a total waste of time and money if it's unlikely to fix it!
For the record, of 100's I've never changed a thermocouple because it's gone faulty of it's own accord, albeit, I've changed one or two burnt out due to incorrect fitting!
To fix a fridge, you need to know exactly how it should work, then and only then can it be determined what needs doing and what does not, anything else is feeling around in the dark. Even if you get it working, you can never be sure it's fixed, only that it works of a fashion
With that in mind and depending on age, I would first suspect the burner, early ones rusted badly, cleaning works but enlarges the slots so gets it working but dangerously, it MUST be replaced.
It's knowing this information and more that's important... not part swapping and guessing!
