How can I link up to a 12 v supply?You will have to have a mains supply to the large connector and 12 volt supply to the other connector as it will not work on mains only. 12 volt is required to operate the control panel.
Do I understand that you want to test the fridge on mains before it is installed in the caravan?How can I link up to a 12 v supply?
Not using the gas or 12v, not towing anmore and van is now staticDo I understand that you want to test the fridge on mains before it is installed in the caravan?
If so you should follow the models (N3000 series) installation instructions (Here)
I'm sorry to have to be blunt, but If you need to ask about how to supply 12Vdc to the fridge I have to conclude you may not have the necessary competence to wire the fridge up safely, and I suggest you arrange to have it tested by a competent fitter.
As this is also a LPG fridge, when it is installed in the caravan it should be done by a qualified LPG fitter in accordance with the Gas safety (installation and Use) regulations.
Yet you still need the 12v to run the control panel.Not using the gas or 12v, not towing anmore and van is now static
That doesn't change the need for a 12V dc supply, and I would add the law says that a gas appliance must be fitted by a competent fitter. The fact you don't intend to use gas does not change the nature of the beast it's still a gas capable appliance and is subject to the regulations.Not using the gas or 12v, not towing anmore and van is now static
