fusible plug
went away at the weekend and the water on the caravar cascade 2 water heater was peeing out of the plug between the fins any ideas how to change this and where to buy them from any help please
They unscrew with a suitable sized socket.
Getting a new one,,,,,none available except for maybe on Ebay, but expect to pay a LOT for one.
If the plug you mentioned is on the outside of the caravan venting for the heater, it is commonly available from caravan spares shops. Failing that the www.caravanbreakers.net should be able to help. They are a very large caravan breaker based in mid wales.
The fusible part of the plug which sticks out into the tank, is an 8mm dia plastic stem about 40mm long, this is attached to a steel bolt that is screwed in from outside, a 13mm 3/8" drive socket and extension is required to get at it in the fins above the burner.
As for availability, I'm still waiting on delivery of new stock albeit it should be any day now?, otherwise, old stock is all but unavailable, as Damian says ebay is probably your best bet, at a price! or no reason why a dealer somewhere might have one?
If though yours has 'blown' but otherwise intact, ie, if the plastic stem is still firmly attached to the metal nut? then I can recharge this for you.
Also to get yourself out of trouble, if your heater is gas or electric heating and as the flusible plug is only for gas heating, then you can block of the hole and use electric only for heating, electric heating having it's own separate over heat protection
Quote " it is commonly available from caravan spares shops"
NO it is NOT commonly available and has not been for about 2 years or more
