Gas supply
Feb 7, 2010
I have checked gas is coming past the regulator on th,e gas bottle but the oven, frige, heater and water heater will not work. No sign of Gas. I have put on another bottle which is part full and its the same. These are both old bottles and wondered if this could be the problem. Or am i possibly missing a secondary switch somewhere. Each unit has its own two way tap and i have tried these each way. It use to work ok! Thanks for any idea's. Tim.
Aug 24, 2009
92
Id be checking outlet pressure of regulator. whether bottle or bulkhead mounted. but first of all is the main tap at manifold inlet on
Feb 7, 2010
Thanks Sproket and Dougie.
This one is actually on our horsebox. Will there be something between the regulator on top of the gas bottle and the 2 way tap that goes off to each appliance?
I simply took the rubber hose off at the regulator on top of the bottle to make sure that gas was coming out. It hissed but i wouldn't have a clue if it was enough pressure or not. Is it likely there will be a secondary regulator? Thanks.
