gas
we have got the blue bottled gas, we tried to run the heating with it, it was great for about an hour then it seemed to go low, when I checked the pressure on the hob the gas was really low, but we had just got a new bottle, anybody got any idea why this should happen.
Hi, Your blue gas will not be working because of the temperature, It stops working when its near freezing. Most will use the Red Propane gas in the winter to avoid this problem.
Stephen
Hi
You sound as if you have butane gas? If conditions were below freezing the gas may have been freezing up. Change to propane (red) it freezes at a much lower temp than butane.
Dougie......
