hi all. can anyone tell me how to remove a 10 year old GB sticker from the rear fibre glass/plastic panel on my van without damaging the paintwork. thanks for any help.
thanks Ian, I will try the hair dryer trick.Without knowing how it is held on there will be no definitive answer. However there are some ways that it may be removed.
If it is a stick on type try warming it with a hairdryer. This may loosen any adhesive that is securing it but be careful not to go too mad. If it held on with sticky pads then get a length of fishing line and feed down the back of the sticker. Using a gentle sawing motion pull the line across the back of the sticker this will seperate the pads from the stickers. All will need to do is clean off the remains of the pads with white spirit.
There may be a fading problem with the paintwork and the space formally occupied by the sticker will be darker than the rest. Solution put on a new sticker. This may be a way of dealing with the problem from the outset providing you can get a sticker big enough to go over the one you are trying to remove.
Best of luck
thanks folks.Unfortunately, if it has been on for 10 years then the surrounding paint will have faded and you will still see the outline. A treatment (gently) with T Cut may blend everything together.
