Grab Handles
Jun 11, 2012
1,525
28
19,685
Hi Steven
I dont know how bad your grab handles are but I had a problem with the colour fading.
I removed mine rubbed them down, infact took all the paint off and resprayed them. End product .... brilliant ... cost
Aug 15, 2010
hi Sir Roger, i know this post was a while ago, just searched and it came up, how do you remove the grab handles? do they "split" along the length to expose the mounting screws/bolts and is there an easy way to split them? hope you are still around and can help, cheers, derek (2002 lunar lexon 640)
blu
Apr 16, 2007
76
Hi
Youre grab handles should bolt through the front panel.Stick youre head in youre gas locker and should be 2 nuts on each one to undo.13mm if i remember correctly.
Thats how it works on a swift anyhow.
Regards
Sean
Jun 11, 2012
1,525
28
19,685
Steven ... Blu is absolutely correct ,inside the front locker on the back of the handles are 2X13mm nuts and washers undo them to remove .
As our van is in storage I removed ours and covered the holes with a bit of gaffa tape to keep the wet out and worked on them at home .
Sorry for the delay in replying
Sir Roger
