Has the kitchen Ominvent been abandoned?
4,870
Looking at the new issues not many, hardly any come with the Omnivent. Are we going backwards?
3,110
They don't have a good reliability record so maybe the caravan makers got fed up with warranty claims - we're on our 3rd and that fails intermittently.
8,358
Strange we had our Bailey for 9 years and never had any problems with the Omnivent fan. It was rarely used at full speed as it was effective at the lower speeds, and we didn’t use it for “ air conditioning “ the van. It was used only for exhausting kitchen heat/ steam.
Jan 31, 2018
1,783
850
5,935
Standard in the Buccaneer. We like it for the summer to get some air into the van.
936
Every van is built to a price, so by not fitting an Omnivent that is a saving for the maker.
2,430
Bailey S5 Omnivent came in useful for cooking to each its own
2,430
Just been looking at the brochure on our 2008 Abbey it got a Omnivent 3 speed fan we always find useful in the summer month for air to each its own
4,824
Yoy were lucky. On our 2011 Lunar Delta it was replaced 5 times in a period of about 2 years. Eventually got an air con.
3,110
No, you're lucky - I can't fit aircon on my Lunar Clubman as the roof isn't bonded sandwich !
4,824
Funny you should say that as in 2015 we were looking at trading in for the newer Delta only to be told that the roof could not support an air con due to the long skylight. We later traded in for a Buccaneer. Not sure what Lunar where thinking of when they designed the newer Deltas etc that could not have a roof mounted air con. Also told that we could not have a Sat dish mounter either.
4,870
My Omnivent is 12 years old, used a lot. I strip and clean the mesh and fan blade annually. Still going strong! Can’t imagine not having it.
4,824
The older ones with the manual switch were okay, but the newer ones with the electronic switch were terrible. At one point we were so fed up with it doing all sorts of weird things we asked the dealer if they would swap it for the older one even if it was second hand. The dealer's answer was that they would just be moving the problem.
8,358
That’s probably why ours on a 2005 Bailey gave no trouble. Such is progress.
1,818
Not seen a lot of them recently but our old Eldiss did have one. Worked well for the six years we had the caravan but that was a 2001 model. It may be standards have dropped.
2,430
I am in agreement l think you were lucky to have air con i don"t think our caravan would have support it .to each its own
2,430
Hi DD would have to agree our Omnivent is just over 12 years and in good working condition
Jan 31, 2018
1,783
850
5,935
Oh dear-should we expect trouble then; our new Buc has one , our good old reliable Avondale ARgente had one and it gave brilliant service. mmmmm progress eh!
4,824
Our Omnivent off our 2018 Cruiser is in the garage as it has never been used.
2,430
Hi JezzerB l don"t think we should have any trouble our Bailey some years ago gave us great service & present caravan so far great ..
Reactions: JezzerB
Oct 3, 2013
890
90
18,935
I think we are going forward,we had one in one of our vans and never used it - it was too noisy and we found it of limited practical use,unless you cook smelly grub !
It worked and had no problems apart from being too noisy and not much use
Jan 21, 2022
13
15
I was wondering if I can order a custom kitchen from kitchen suppliers to install in in a caravan? Has anyone do this before?
8,358
I’d think a domestic kitchen unit(s) would be far heavier than the units fitted to the caravan, and would not only increase your unladen weight but reduce your payload. A better option could be to find one of the companies that convert vans to campers as they use lighter weight materials and components and can make it exactly to your size and layout.
Reactions: ProfJohnL
Jan 21, 2022
13
15
As far as I know you can choose the material you want your kitchen to be made of, at least this is what I was told by a local bespoke kitchens eccleston contractor, you choose the material and the design.
8,358
As far as I know you can choose the material you want your kitchen to be made of, at least this is what I was told by a local kitchen contractor, you choose the material and the design
We’ll be worth talking to them in more depth to see what the design would be. But keep an eye on weight.
