Heaters
Sep 6, 2007
9
Hi
Can anyone advised me to what is the best portable heater to have in the caravan,one that can be left on low all night. Ive seen oil filled and halogen, but not sure which is best and effecient.i feel the fan one might make the air too dry so that one i ruled out unless someone thinks differently.
We always leave the caravan heater on 1kw electric convector setting all night, never had a problem. If it's really cold we leave the wash room door open to let the warm air cirulate. In a previous van where the caravan heater was not up to much we used a 2kw portable convector heater which was very good.
Dec 23, 2006
788
Kestrel,
What type of heating system is in your cravan? Heaters in caravans built in the last few years can be run on 1/2, 1,or2 kwt mains or 3 kwt gas. Both mains and gas being thermostatically controlled. If you need additional heating for a particular part of the caravan, ie the washroom, i have used a Dimplex Coldwatcher for years. You can get 1/2 or 1kwt ones and they have adjustable thermostats. They can be stood upright or laid on their backs and are not fan operated.
Hamer
Sep 13, 2006
1,411
Ditto the others on using the van heater but if you do not have one.
We use a small sungas heater in the awning for non hookup sites and would never use it in the van or when sleeping in the awning because of the need for good ventilation.
For hookup sites we have a small halogen heater which is great in the awning because of the warm light it gives off, for this reason it would be no good for use in the van - simply too bright.
I know this might be stating the obvious but if you have to use an electric fire in the van make sure it is nowhere near any bedding or clothes that might fall/come into contact with it - after all even the biggest caravan is still quite a restrictive space when you are moving about during the night.
4,405
Hello Kestrel,
At the risk of repeating what others have said, for over night heating and safety probably a convector type heater may be best. They are quiet, and usually have a built in thermostat so they will modulate the amount of heat they produce to maintain a preset temperature. Care should be taken to prevent any thing from covering them, but in the event usually the thermostat will prevent over heating.
The draw back of convector heaters is that the air inside the caravan will tend to stratify, with the hot air at the roof level and quite cool air a foot level. This can be uncomfortable. I have actually measured the temperature range in a caravan and found air at 5C at the floor and 30C at the roof. (external ambient of -5C)
A fan heater does much better at mixing the air (blown air heating on a caravan heater does better still as it ducts the air) But there is the noise factor of the fan, and the heater is more sensitive to being covered or having its air ways obstructed.
Radiant heaters are good at warming surfaces in direct line of sight of the element. The down side is that surfaces in shadow can be much cooler. The difference between warm and cold surfaces can very noticeable and consequently uncomfortable. The majority of shop bought infra-red heaters use elements that operate in the shorter wave-length visible light range. This makes them quite bright. There are more expensive Quatrz element heaters that use long wave-length IR radiation which are not as bright but produce just as much heat.
Some advertising make out that a particular models of heater are high efficiency, and by inference that others are low efficiency. This is inaccurate and misleading. One of the beauties of electric heating is that by virtue of convection, conduction and radiance you will actually get all the possible heat from the electricity used 100%. Even the power lost in the cables comes out as heat.
It is a characteristic of heating air that warm air can hold more moisture than cold air. It does not dry it out, the same moisture is there but because warm air can hold more it feels drier. As the ejected air from a fan heater is much warmer than its surroundings, it feels particularly dry, but as it cools towards the ambient it will loose it apparent dryness. Radiant heaters do not directly heat the air only the surfaces they shine on. But as the surface is warmed, the air next to it is warmed, so ultimately the same overall effect will be achieved regardless of which type of heater you use.
The choice is yours.
Sep 6, 2007
9
Hello Kestrel,
Hi All
Many thanks for your replies they have been a great help, i will let you know what we decide.
May 21, 2007
894
Kestrel,
We purchased a small oil filled radiator for use in the van.Ideal for keeping the chill off .It has a thermostat control which makes it safe.Anyway last year(first weekend in November)we decided to take the van to a site near Westonbirt Arboretum.As it was frosty we decided to take the radiator with us.It was brilliant.On the Saturday we put the radiator on for the day as we visited the arboretum.
When we came back and opened the van door we were greeted with a very welcoming wall of heat.
'What an amazing little heater' I said to my wife.We prepared something to eat and after about an hour I remarked that we needed to turn down the radiator as it was really hot.I got up to do that and as I went towards the back of the van I noticed that we had left the gas fire on all day and didn't notice.Talk about laugh.No wonder we were greeted with a wall of heat.
But we are very happy with our little heater.
Dec 6, 2007
414
Hi we fitted 2 400W tube heaters to out van. they are about 2 foot long and mount with 2 clips. one is in the bathroom and the other right at the front, on the font of the box the bed slats drop into. They 'keep the chill off'!
the bathroom one is great to be honest keeps the washroom cosy, the other one helps the gas heater to warm the whole van evenly.
they were about
Dec 23, 2006
788
Gareth,
Could you please tell me where you got the tube heaters from as I could do with 2 for under bunk heating.
Hamer
Dec 6, 2007
414
Hi Hammer
yes we got them from our local electrical shop in Barmouth N Wales. I think they are Ring brand. I'll have a dig see if i can pull up a part no. or link on ebay.
ideal for under bunk! we pull the slats out over the front one, the dog wriggles his way the whole way under to lye against it!
Gareth
Dec 23, 2006
788
Hi Gareth,
Small world! I live next to Portmeirion so will call into the electrical shop in Barmouth on Tuesday.
Many thanks.
Hamer
Dec 6, 2007
414
Hi Hamer
small world!
I often pass through there, i drive the X32 Aberystwyth - Bangor bus!
Helen, my other half, says they are Glen brand. they are about 2 foot long ans 3 inches thick. white in colour. kind of thing you use to keep frost out of sheds, green houses etc.
let me know if you get them.
Gareth
Dec 6, 2007
414
Hi Hamer
small world!
Gareth
http://cgi.ebay.co.uk/Glen-Tubular-Heater_W0QQitemZ230179976397QQihZ013QQcategoryZ41987QQrdZ1QQssPageNameZWD1VQQcmdZViewItem
cut this into your search bar, this is about identical to ours!
4,405
Gareth,
Hamer
Check out Screwfix who also do similar devices
