Help electrics !!!!!!!!!!!!!
May 26, 2009
98
Hello all, I recently bought a new Ford Galaxy that had factory fitted retractable tow bar. Gone to move Caravan as going away Saturday and the electric plug on the Car is different to the normal one on the Caravan, any help pleeease,thanks Kim.
Feb 10, 2009
85
Hi Kim,
Either the caravan has a 13pin socket or the car has the 13pin socket. Does your caravan have 2 x 7pin sockets (Grey & Black)?. You need to look at the car socket and count the total number of pins/holes in the socket.
From a good caravan accessory shop you can get an adaptor plug, but this will only give you the legal road lights (side, brake indicators, hazard and fog lights). It will not work the fridge or caravan leisure battery or any other internal 12 volt on the caravan. But it would let you get away on Saturday.
Longer term and you will have to either change the plug(s) on the car or van. Since you say it is a new Galaxy I would assume that it has been fitted with the new 13 pin socket.
If you are quite good on the electrics you will probably find it easier to change the caravan socket(s) to the 13pin socket.
You get a 2 metre length of 13 core cable,a 13 pin socket and and a 13 pin jointing box, and connect up the appropiate wires
3,266
46
May i add, check that your 13pin? car plug is fully functional, so do not wire up for fridge and battery charging.
A quick test at your local towbar centre will confirm.
