Help me find Swift Charisma fuses for water pump please?
Aug 4, 2024
8
Hiya
I think my fuse went for my water pump. Handbook says Fuse 7, but the fuse board isn't in the place the handbook says but must be somewhere. Please can anyone help me?
4,255
From another Forum the same question cropped up
They are located under the right hand side front seating between the water heater and wardrobe unit, about 1 ft from floor level on the side wall.
Jul 15, 2008
3,747
841
Where is your switch to turn your onboard battery charger on/off?
The bank of fuses should be nearby.
Is it a switch on a Sargeant metal box under one of your front seats?
If it is, the fuse bank should be behind a plastic cover on the front of the metal box.
This cover just pulls open.
May 2, 2020
277
111
4,735
Hi
I repaired a fault on a Charisma of around that age a few years ago, if I remember correctly the 230v board was in the wardrobe and the 12v fuse box was on the outer wall below the wardrobe floor that was accessed by removing a screwed down panel on the wardrobe floor near the outer wall.
Gra
  • Wow
7,387
Hi
Gra
That’s a real design winner if ever I’d heard one.
Jan 19, 2002
1,634
492
You seem to have a handbook that is misleading- if you google ‘Swift Handbooks’ and enter the year of the van you might find an alternative version or a handbook for a similar age van that will guide you correctly. I think you will find that many handbooks are generic to a range and therefore do not always show individual differences within the range.
Aug 4, 2024
8
Thank you I'll double check...
Aug 4, 2024
8
Thank you, I'll do that!
Aug 4, 2024
8
Hi
Gra
Wow, I'll have a look at this. It sounds likely to me as I've searched everywhere else nearly!
