I also have a GT60. When you open the door to the casette at the bottom right hand corner there is a connector,have you got voltage there.If not check fuse inside van at fuse panel under seat front.If you have voltage at connector,it may be pump stuck if not used recently.Drain water from tank and remove tube on pump, then remove pump by pulling lugs each side of pump outwards and pulling pump down from tank.You can then see if impeller turns,if not, usually you can move it with a small screwdriver poked in.Other than that if voltage at connector ok,fuse ok ,then prize cover with push button on top off tank by going round with a thin knife to part seal and check switch under button.
