Help needed - Alko wheel lock
Feb 5, 2023
10
7
15
Firstly thanks for taking the time to read.
Please excuse me if a silly question. I'm very new to caravans and learning. I recently bought an alko wheel lock and went to fit it today, after watch some you tube videos I didn't find a plastic screw in the tube I have to screw the bolt to I found a sticker and then under the sticker was a screw already screwed in (see attached). Is this normal, I have phoned the chap I bought the van from and he claims he has no idea. Any thoughts on what type of socket I need to remove this please?
9,067
Contact Alko UK. They will help. It’s not uncommon. The security “ plug” was inserted by Alko. The link plus links from it explain the background history of why they did it.
Reactions: Flash and Jcloughie
2,664
Good advice from OC. Alko are a helpful company in my experience.
Reactions: Flash
5,249
Yep you need the key to remove that lock and I don't think it is an ALKO lock for any wheel lock, but they will confirm.
Reactions: Flash
9,067
There’s a picture of the type of key required in one of the links I posted above. It’s different to the normal Alko wheel lock security bolt.
Reactions: Flash
5,249
The lock could belong to the Bulldog type wheel lock as the shape for the key does not look like an ALKO version.
3,559
Is this the "blocker" that Alko fit in the receiver to stop third-party locks, eg Bulldog, from being used - so there should be a matching key with a genuine Alko lock ?
9,067
Yes if you read my above post there's a link to a post by Damian that describes the whys and wherefores of the Alko versus Bulldog actions.
5,249
Did not think it was legal to fit something like that?
9,067
Here’s a picture of the Alko removal tool and the screwed plug that was inserted into the receiver ( reverse order I’m afraid) to prevent Bulldog locks being used. “Legal”? That’s a recipe for a massive diversion. 😂
Feb 5, 2023
10
7
15
I thought this but the socket i got with my kit doesnt fit it, it fits the bolt that i need to screw into this place to connect the lock to
Feb 5, 2023
10
7
15
thanks for that, I did follow the guide on Alko when i bought it to ensure i had the correct one for my van
Feb 5, 2023
10
7
15
Was the lock bought new or secondhand ?
2nd hand (yes wanted to save a few quid, now learning my mistake, but that's part of the learning curve),
I've contacted alko and sent them a picture so hopefully will get an update soon
9,067
I bought second hand Alko lozenge complete with lock from a Swift dealer. I then purchased another Alko lock and sold the second hand one. So I too saved few pounds. When you get it all sorted don't forget to register your lock with Alko as if you should loose keys their key maker (Lowe and fletcher) will not provide replacements. Hopefully the previous owner of your lock has de-registerd it if in fact they registered it in the first place.
Reactions: Jcloughie and Flash
Feb 5, 2023
10
7
15
Thanks for the heads up
